- Nov 13, 2001
- 15,361
- 416
- 126
I bought the monitor because I needed the extra inputs plus it has actual OSD, see pics below, and everything I read, that scared me after I bought it, was it was to have this massive lag because of having those extra inputs.
Well I played
DiRT 2
DiRT 3 which I ended up getting the best time ever first try after hooking up and testing
Bioshock
Half Life 2
Peggle
FEAR
Prey
And I had to ask myself, where is all this lag I read about on OC.net. I even turned on VSync because that was to make things even worse and it didnt. I had it on for DiRT3 and I didnt crash one time, as usual, and posted the best lap time I ever did first try after hooking this thing up. So if I was to have this "lag" why was I doing so good. In all the games driving or FPS when I turned/moved it moved with NO lag I could see at all. Which makes me happy I bought this monitor. I got OSD, 3 inputs, and high res.
Anyway enough about this, that I could not find, now about the monitor.
One word
AWESOME!
Text, colors, brightness, contrast, movies, they all just POP off the screen. Reminds me of the good old CRT days, which I still have my old 22" crt in the basement that goes much higher then this thing does, but the dot pitch and higher res reminds me of them old days playing at max res and everything was so clear. I know some of you kids are like "whats a crt monitor"? Its something that has an even higher res and didnt cost quite as much. I think I paid $120 for my 22", which was HUGE back in the day.
I tried a Blu Ray movie, 2012, using just my Powerdvd 10 program and thats all and it played so Im guessing this is HDCP compliant, or at least this monitor is.
I couldnt go higher then 60hz no matter what I tried so no 120hz for me
but thats alright for it doesnt bother me like it does some folks.
Stand is wobbly but I have no plans on hitting it as I play, and my desk is sturdy so it wont wobble around.
HDMI works fine. No higher res then 1080P though.
My ac adapter has the larger sticker that actually says 110v to 240v on it. Not a paste on sticker on the label that says 110v ready. See pic below. I did have to use an old monitor cable for the cable it comes with is wrong, and they dont give an adapter. No big deal for me at least. It does get warm, not hot to where you cant touch it, but def warm. Im disabled and play/sit here for 12+ hours a day so I will see how reliable this monitor/ac adapter is.
VGA I havent tried yet because I need an rca to 3.55mm audio cable, monoprice here I come. I plan on using it for my cable tv hook up so I can watch tv on here like I did with my old Sceptre 32" tv/monitor I was using that this replaced.
Got mine from Green Sum and it left on the 31st and made it to my doorstep the 2nd. So 3 days DHL.
No dead pixals I could find. Slight light bleeding in both right and left lower corners but no OMG its so bright I cant stand it! Its just very slight and not really noticeable unless the lights are off and your looking for it. I believe I paid $379 for it shipped from Green Sum on fleebay.
All in all though. If your looking for a MULTI monitor, high res, and dont want to pay much, and worried about "lag", I would say get this one. I found NO LAG whatsoever, and if there is I dont know how to find it, or how they found it, because I did great in all the games I have so far tested with it. I just feel that they assumed that since it has more inputs that its then gotta have more lag then the single input monitors do. Buy one and actually try it before you just say these things is what I got to say about that kind of thinking.
Now pics:
Well I played
DiRT 2
Bioshock
Half Life 2
Peggle
FEAR
Prey
One word
AWESOME!
Now pics:
