the circuit breakers (2 ganged 30 amp) for the water heater keep tripping
i suspect the heating elements first, right?
i am going to get a meter (my old one is crap, so i'll use this 'reason' to get a new one) and then
turn off the breaker
check each lead on each element to ground, isn't it most likely that one of the elements is grounded? isn't that the most common way the elements fail? or not? or do they short phase to phase? if so, what is a normal resistance reading phase to phase?
if i can't determine it is one of the heating elements, then what should i check? the breakers? does home despot test circuit breakers?
if i need to replace a heating element, about what do they run? $10 $30 $40 ?
are the heating elements in dry wells or will i have to drain the tank?
thank you
thank you
