phantom309
- Jan 30, 2002
- 2,065
- 1
- 0
Complaining that your electric guitar sounds bad when it's not plugged in is like complaining that your car handles poorly with the tires removed.
Originally posted by: thomsbrain
KaBudokan, thanks for that reply, I was getting increasingly distressed at the ignorance of each new post as I scrolled down.
Adjust the tremelo to where you want it to sit (1/8" is typical, you need to be able to pull it back a bit to handle the thing going out of tune after you use the whammy bar). Then adjust the truss rod accordingly. If you don't know what a truss rod is, you should just take it into the shop.![]()
Originally posted by: ThaPerculator
Could be a lot of things... could be anything from having a screwed up neck, to wrong saddle height, to maybe lowering your bridge, to needing a new nut from your strings digging down deep...
Originally posted by: Angrymarshmello
Originally posted by: OREOSpeedwagon
My low E string buzzes when I'm just playing, not thru my amp, but when I hook it up to my amp it sounds fine so I don't worry about it. I've restrung it i don't know how many times and the low E string is the only one that buzzes. Its okay with me as long as it sounds good through my amp =)
That's my exact problem! Sounds great through the amp, but buzzes a lil without it on.
Originally posted by: kevinthenerd I'm looking for good pickups, though... any suggestions?
lol Yeah, I was kind of worried about the shape his guitar would be in before too long, tweaking this and tweakign that without any idea what was going on.
Seriously rpc, check out that site - it's not rocket science, and once you do it a few times you'll realize how worthwhile it is to take the time to learn to do a setup and do it right. I've bought guitars from Guitar Center that were on clearance because they were set up terribly, only to come home and take 1/2 hour and make them play just about perfectly.
