- Sep 19, 2001
- 4,711
- 2
- 76
My battery light just came on and I'm not sure if it's the battery or alternator. Any way to test it by myself to see if it's the alternator?
*EDIT*
Checked battery with reader while engine was on and it reades about 12.5, which is normal. The light just came on about 2 hours ago. I'm thinking it's the alternator right now. Any idea on how to make sure it's the alternator?
*Day 2*
This morning when I started the car, the battery light never came on. I drove it to work (about 5 miles) and seems normal. Could the alternator just be "hiding" its sickness from me and choosing to crap out in the middle of rush hour? If it helps, the other week while I was cleaning the car, I removed the negative from the battery when the radio was playing (one key turn away from the off position). Maybe that was what killed my alternator?
When cleaning the wires, I use water and baking soda. My friend sake Coke works also. I don't have any Coke or baking soda, so would other varieties of pop work (ie: Sprite, Root Beer, etc...)?
*EDIT*
*Day 2*
