Originally posted by: Kaervak
When you should replace them is simple. Take a penny and insert it in the treads with Lincoln's head upside down. If you can see the top of his head, replace your tires.
Actually, it's even easier than that 😉
There are treadwear indicators molded into the tire tread. When the tread reaches 2/32", you can see the bars across the grooves of the tread.
JC
JC
I've never let my tires get that low, so that's news to me. 🙂
