YACT: What's going on with my oil pressure gauge?
elektrolokomotive
1,637
'95 mustang, 6cyl, 121,000 miles.
Car runs like a top. Only problem is, my oil pressure gauge is possessed! It goes from looking like it's dead, to bouncing up in the middle of the range, to running down near the low end of the range. Is this a bad sensor? I'm not much of a gear head, but I know how to use tools. Is this something that's easily fixed?
SaintGRW
1,048
my stock one does that......
91 1.8L Eclipse *winter beater
although that thing burns through a quart of oil a week. sorry can't help ya.
TallBill
46,017
62
lol, mine does the same thing.. i just let it be :p
'95 crown vic ~110,000 miles
maybe its the ford '95 sensor thats bad
Eli
Super Moderator | Elite Member
8
Highly doubtful your oil pressure is actually fluctuating like that.
Just a bad sensor, or a short somewhere.
Quixfire
6,892
Have someone do a mechanical pressure test on the engine to see if it's your engine or the sender/gauge causing the problem.
Most shops should charge over one hour labor, $50-$75, to do this.
Good Luck,
Quixfire
elektrolokomotive
1,637
Good Luck,
Quixfire
I had it tested several months ago. There wasn't a problem with the pressure then. The gauge was a little flaky at the time, reading kinda low. Last couple of weeks is when it's been going haywire.
TallBill
46,017
62
btw, theres NO way im spending 50-75 bucks on a test for a car that cost me 2000 bucks after tax, license, and registration. elektrolokomotive is more then welcome to on his. Eventually i'll spend a little bit to get new brakes on my car, and that wont happen untill my brakes go out :D
