YACT: WHAT IS THIS HOSE CALLED?!? PIC HELP!
Chiboy
3,814
Pic Ok, Its the hose with the arrow pointed to it. Mines has a hole in it. I dont know how it happened. I know it has to be able to take a lot of heat, that is all I know about it. So when I go to the dealer tomorow, what do I tell them I need?
Fiveohhh
3,776
what runs in it coolant? air?
Chiboy
3,814
Air
Chiboy
3,814
Originally posted by: fivespeed5
The dealer might not give you one since you're a thug.
I'm going to dress in a bussiness suit so that wont happen.
Oct 19, 2000
17,860
4
Damn, that took me atleast a minute to find the damn arrow. Like trying to find your mouse cursor on a 1600x1200 screen without moving it.
Chiboy
3,814
wheres it go to?
Intake Manifold? I dont know where its coming from though. I think its a pollution hose/pipe.
puffpio
1,664
It looks like the ventilation tube. not hte PCV vavle, but the other one that just plumbs into the intake before the throttle body..OTOH if this is plumbed into the intake manifold after teh throttle body then it is the PCV valve
Chiboy
3,814
I'll just ask them to come out & take a look at it. I have to go get it in the morning & than have it installed which should take about 5mins to do since it only has 2 silver things holding it.
Ness
5,407
It's the reverse downthrust ventilation exhaust coolant flow regulation tube. Cost you a million dollars to replace. And that's the labor.
warcrow
11,078
11
Daewoo makes cars?! Arnt they the same company that makes microwaves and tupperware?
Twista
9,646
