yact: what does the mass airflow sensor do?
MeanMeosh
3,805
... and do i need to get it replaced immediately if it goes faulty?
well, i know i prolly should, but i'm a little tight on cash... can the replacement wait? the mechanics told me that this is what makes my check engine light go on.
Yossarian
18,010
It measures the mass of air going to your engine so the fuel injectors can squirt in the right amount of gas.
NogginBoink
5,322
All kinds of problems can cause the check engine light to go on.
Your first task is to find out what caused the light to go on. Many auto parts shops will do a computer scan for free. Start there.
LAUST
8,957
listen to Noggin, go get it scanned, MAF's are pretty pricey to just go buy one without verification it's the actual problem... I have only known 1 MAF to go out too, and when it did there was no SES light, the car just DIED.
cavemanmoron
13,664
28
Originally posted by: bunker
Ummm.....
According to the mech, it is the mass airflow sensor
is it a Ford?
common,they have a cleaning kit available,cheap to try to clean the wire off
you can try some good electrical cleaner,for cheap,first,
unhook the battery before you try anything.
