YACT: Using CC going up a long, steep hill
jtvang125
5,399
51
Never heard any warnings of this but I usually turn off my cruise control when I'm going up a long, steep hill. What do you guys say?
tm37
12,436
As long as the engine is not lugging or the tranny is not shifting between gears repeatedly you should be fine
NutBucket
27,152
635
Yeah, as long as its not struggling up the hill no problem. Besides, an auto trans would likely downshift anyway.
dug777
24,778
4
lol, some of use have manuals here ;)
That said, my folks Prado just drops out of CC when the torque hits a certain point, well before any damage is done...
dug777
24,778
4
If it's hilly country you'll get better fule consumption using the accelerator yourself anyway...
jagec
24,442
Originally posted by: RossMAN
I need help, I thought cc was credit card.
WTF?
You spend too much time in Hot Deals :p
Cruise control.
Not at a constant speed...
jaedaliu
2,670
WTF?
Cruise control.
depends on why you're using cruise control. The only time I do is when I'm trying to keep myself from speeding too much. Unfortunately, I get bored and take cruise control off if I'm close to my destination.
dug777
24,778
4
I've seen a good few tests that show CC is crap in country that's hilly, since it tries to hold your speed on the hills and overspeeds over the top, rather than taking the slow down in your stride manually...
NutBucket
27,152
635
Yes, I have a manual as well. I assume my answers are directed towards people with auto trannys since the VAST majority of people have them.
jagec
24,442
I guess I was spoiled...the last CC-equipped car I had could hold it within 1MPH on all but the steepest hills, up or down :Q
Maybe it had PID rather than straight PI control...or was just better tuned for the car.
Granted, if you use your momentum to climb hills (but lose a bit of speed along the way), and let gravity speed you up on the way down (but NOT stick to a constant speed), you save some gas.
jtvang125
5,399
51
I had a manual before and it wasn't that much different. The car was able to hold its speed even in 5th gear (set at 70mph). If I turn off cruise control half up the hill I would have to downshift into 4th to keep my speed up.
BobDaMenkey
3,057
I don't think that it would wear out anything any more than regular use of the Cruise. I don't know from experiance though. There are no mountains to climb in Pheonix, and I have a Manual truck.
