When i start to depress the gas, i hear a tapping sound coming from near the glove compartment. At first i thought there was something inside moving around, but i emptied everything and it continues to making the tapping noise. It only occurs when i step on the gas in gear. When i depress the gas in neutral it doesn't make the sound. I read and done some research, at first i thought it was a transmission problem but i read something about an optispark going bad?
'99 Accord 4-cyl 82k
has anyone had this problem before, and how much would it cost to have optispark replaced?
Edit: nothing seems to be loose. i tried coasting in "N" and shake the wheel violently to induce movement and it doesn't make a sound.
i've done further research and it maybe a leaky exhaust? i might have to change the manifold?
also wanted to get some price quotas before i nose dive helplessly to a mechanic.
TIA
TIA
