Squisher
My '91 Dakota (318ci) starter started giving me some problems about two weeks ago.
I'd go to start it and you'd hear a clunk like the battery was dead, then if you turned it off and started it again it would start, no problem. When it did start, motor turned over no problem, not slow at all.
So, I figured the starter was binding up, then starting on the second try.
But, when swapped out the starter, now I have nothing. Turn the key and lights dim, but no noise, no nothing.
I thought I was a dummy and it was the battery all the time (even though I checked that first) so I tried to jump it and nothing again.
I figure either Autozone sold me a clunker or it might be the neutral safety switch. But, if it was the switch, why would I have been able to start it for the past two weeks on the second try????
