YACT: Speaker Replacement
dakata24
i have a 1995 acura integra sedan. id like to change out my speakers with aftermarket ones.
the front speakers are 6 1/2" and the rear is 6x9". should any 6x9" & 6 1/2" speakers fit my car? ive checked online at bestbuy, circuitcity, goodguys, etc. and im getting conflicting information as to what will fit my vehicle.
any websites that give accurate information as to what will fit my integra? thanks. 🙂
Crutchfield.com is the only source I really trust for fitting. Not every speaker will fit, due to depth, top mount, bottom mount, etc.
really? i had checked there too and the only 6x9" speaker replacement is by some brand called Dual. i might have to drop by a store and see if there's anyway around to open up my options.
