YACT: replacing brake lights
Mookow
10,162
Well, I'm not bad with tools, but I have never screwed around with this before, so...
My mom's 1997 Civic LX has brake light that needs replacing. Rear driver's side light. Specifically, the light on the body, not on the trunk. There is an autozone or a pep-boys around... how much should I expect to pay for a new bulb? Any certain brands to avoid? It looks like, from a quick flashlight survey, that I'm going to be loosening the housing for the bulb from in the trunk, right?
Mainly I just want a price-check, the install should be straightforward.
CraigRT
31,440
it's a bulb man... it's probably $2
just buy whatever the right bulb is... thats what I always do.
NeoPTLD
2,544
they look like a small lightbulb with two contacts on the base and have two filaments.
If there is a piece you have to remove to gain access to either lamps, now is the time to replace both. I'd actually replace all the lamps that you can gain access to through this disassembly. Lamps are cheap and you'll minimize having to disassemble again when your other bulbs go out.
If the two sides are completely independent, you don't have to change the other one.
ynot167
279
You really should replace it yourself...a couple of things to remember:
Do not touch the bulb with your bear greasy hands.
You should replace both right and left at the same time.
It should cost only a couple of bucks.
good luck
mugs
48,920
46
Only buy a bulb if it comes with a sticker to put on your car so that everyone knows you use brand X bulbs and they give you Y extra horsepower.
NeoPTLD
2,544
good luck
It doesn't matter if you touch brake lamps with your barehands ;)
The statement is only true for halogen bulbs like the headlamps.
Pepsi90919
good luck
dude these aren't halogen lights
GalvanizedYankee
6,986
How many ATOTers does it take to change a brake lite bulb? :D
OP, it's in the owners manual.
Mookow
10,162
And what do you think the chances are that my mother kept the owners manual? :p
[Keanu from Celebrity Jeopardy] Yet [/Keanu] ;)
