YACT: Problem with Air Conditioning
cchen
Something is wrong with my a/c. I press the button, rpm's drop, but hot air blows out. I looked under the hood and the compressor is on. Tried refilling with freon, still hot air blowing out.
What could be wrong here?
get some of the uv charge and a blacklight...charge it...let it run for a few mins (at ngiht would be easiest) bring out the blacklight...and find ur leak
**This can only be done with 134A refridgerant btw ***
What you wanna look for
If the compressor is turning, the freon charge is fine, (All Motorvehicle A/C systems have a low pressure cut off switch which saves the compressor should the freon leak out), most likely you have a stuck heater duct door or a plugged accumilator/reciever/dryer.
Start up your vehicle, turn on the A/C, carefully touch the large and small hoses running to and from the compressor, the small diameter pipe/hose should be very hot while the larger diameter pipe/hose should be frosty cold, if this is the case, you have a stuck air door inside the heater box, if this is not the case, you have a plugged accumilator/reciever/dryer.
Depending on the car you could also have a stuck heater valve allowing coolant to flow through the heater core heating the cooled air.
Please post you make, model and year.
i have 1990 mazda miata
here's some more info - i just drove with the a/c on, the air that came out was significantly cooler than with the a/c off
another thing, this happened a while ago, the a/c was left on a while ago, and my mechanic said it caused some belt to break.... not sure exactly what happened there as i was still away at school...
let me know what you guys think
its too damn hot without the a/c
Sounds like a restriction in the system, you should have a qualified mechanic look at and perform a performance test.
I would need pressure and temperature reading to diagnosis further.
