YACT: Patching a Window Washer Reservoir
PCMarine
3,277
Hey guys
So my dumbass friend drove his [flaming lipstick red] toyota matrix into a rock in an apartment complex. The rock tore off the plastic guard underneath the front bumper, and also punctured a small hole in the window washer fluid reservoir.
Thus, what can we use to patch the hole? Caulk? Blow torch and another piece of plastic? Epoxy?
Thanks for any help.
Mermaidman
7,987
93
Chewing gum :D
Seriously--how about getting an intact reservoir at a junk yard and replacing the broken one? How big is the hole?
PCMarine
3,277
Originally posted by: Xanis
You might have to buy another one. How big is the hole?
My friend was able to stop it covering the hole with his finger... a fairly steady drip (1 drop every half to full second?)
xanis
17,571
8
I have two words for you then: Construction Adhesive.
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,589
$5-10 junkyard.
Let him replace it as a penalty
Fiat1
880
Cut up a plastic soda bottle a little bigger than the hole and use some clear silicone caulk to act like glue. ;)
lokiju
18,526
JB Weld.
It's a two part epoxy and will last longer than the car.
Also, who else thought this was about patching Windows at first?
Rubycon
Madame President
Aug 10, 2005
17,768
485
If the vessel is constructed of polyethylene most epoxies will not adhere well even if the outer surfaces are roughed up. Your best bet is to seek replacement.
Tom
put a plastic bag inside and add fluid. then use the cap to seal the top of the bag shut.
Rubycon
Madame President
Aug 10, 2005
17,768
485
That won't work if the pump is at the bottom of the bottle. :p
If the pump is elswhere and there's a centered dip (supply) tube in the cap then a bag will work. Still about as temporary as using oatmeal to seal your boiler. :Q
Tobolo
3,697
Originally posted by: lokiju
JB Weld.
Yeah that would be me.
Triumph
14
Polyethylene is the traditional plastic for clear reservoirs such as washer fluid, coolant, brake fluid, etc. It's very resistant to chemical attack, which also makes it very hard to repair. So yeah, pitch it or stuff it with bubble gum.
