Originally posted by: Lithium381
you'd be fine with dino oil......i've got an oil leak, it'd leak more with synthetic cause apparently it's thinner, that and it'd be more expensive! I change my oil about once every 4 months, depends on how much i drive, less over summer
It's not thinner... viscosity is viscosity.
A 10W-30 synthetic and a 10W-30 conventional oil should have the same viscosity at operating temperature. The difference is that synthetic oils' molecules are all uniform. It doesen't contain any of the impurities, ie: large molecules like waxes and other things that are naturally found in conventional oil. That's what causes conventional oil to resist flow so much in colder temps.
On the other side of things, this also gives the oil much better high-temperature stability. Synthetic oil doesen't boil off like conventional oil does, changing its viscosity.
And finally, yes.. synthetic oil generally has a more robust additive package to begin with, so you get better detergency, friction reduction and wear protection. That's why you can theoretically run synthetic oils longer than conventional, as long as certain requirements are met.
First, your air filter can't suck. Yes, K&N air filters suck. They flow well, but due to the laws of physics, that also means they flow more dirt.
Second, your oil filter can't be a POS. It is your oil filter's job to catch anything that gets past the air filter(which
will eventually make it into your oil..), PLUS helping to remove contamination caused by the engine itself.
Third, you can't guess. There are just too many variables. The only way to accurately judge the state of your oil is through oil analysis.
Modern conventional oils are excellent lubricants. Therefor, I recommend buying whatever oil you want. Buy the cheapest if you want. Spend the extra money on a quality air filter and oil filter. Afterall, even the best oil on the planet is rendered useless if there are solid particles in it.
Follow your manuals oil change interval recommendations. I think for many new cars, it is generally 3750 miles for Severe Service and 5000 miles for normal use. Believe it or not, most driving would be considered severe service. City driving, stop and go highway driving, light-to-light racing, long, steep inclines requiring a downshift, leadfoot, extreme heat, extreme cold, extreme dust, etc....
If your engine experiences any one or a combination of those things, you can't really change your oil "too much".. lol
