Originally posted by: Eli
Originally posted by: Bekker
BTW, you said in the chilling cold .... are you sure your antifreeze is sufficient? I ask because it is possible for it to freeze solid from a slush when you first heat the engine up, perhaps in the block. That can blow freeze plugs or crack blocks, either of which will cause oil to overheat. I don't want to be an alarmist, but were it me, I would immediately examined by a mechanic.
Bekker
It's a good thing, too....
LOL ... yeah, think maybe I left out a word? Come on, leave me alone. I am trying to make up a test for marketing research to give my students Monday and my brain is fried. Think it should have read immediately
have it examined.....
As to the oil rising while running, I assume Scghadenfroh knows how to sheck the oil and wiped the dipstick clean before measuring it after running and that he did not check it with the engine running. If not, the oil reading he took meant nothing since it was probably splashup as the earlier poster said.
As to what the funny what kind of car (GM) comment, brother can I relate to that. One Cadillac with Deisel engine, blown headgasket and $400 repair, second a Grand Am owned by daughter, third a Seville owned by me (I was really dumb on that one because when I checked the oil before making a "must" trip, the oil level was too high and I knew that was likely the culprit, but I had to make the trip anyway.
Damage? Another $400 HG repair, but too much damage had already been done. After the repair, on the way home from the shop, threw a rod and the entire engine had to be replaced. No used anywhere in US according to salvage yard searches (4.1 liter bad engine reputation) and GM dealer was unable to locate one anywhere through GM network ... finally found one new/reman in the entire US (had called the reman plant and they ran split shifts, half year one type of engine, next half the 4.1). Cost of engine, 2100 cause the local Service manager was a friend (GM price was $3700) and I had the vocational tech dept of our school do the replacement. About $2500 total. Now I have a 98 Aurora that is leaking oil topside and they just put dye in it because it looks like another headgasket job. Hope to heck not. What did they all have in common? GM engines. How many friends or relatives driving Ford or Chrysler have had to replace HG during that time? None. Seems like I would learn sometime!
Hope it is the thermostat, Generally, when mine have gone out, they have stuck and the engine overheated very fast.
Bek
