YACT: Need some glue/epoxy/stuff for plastic molding and exterior trim..
Eli
Super Moderator | Elite Member
There's some trim on the exterior of the Camry that's loose and we want to fix it, not really sure what to use.
Also, the plastic molding around the doors is loose..
Any specific recommendations as to what we can use to glue it back in place? Something that will last forever would be nice...
Maybe some sort of epoxy for the exterior trim.. something similar for the interior? Might need to be something different if they're 2 different materials.. dunno?
3M, i believe they make a product for putting on badges that is removed without much effort should you decide to take it off later. Any product from 3M should work. 3M adhesives
Thanks.
That's exactly what we ended up getting after looking at all the choices at the auto parts place. 🙂
