Spike
Let me start off by saying I know nothing about cars. I can change the oil, sparkplugs, and a few other things but my knowledge stops there.
Just this morning I noticed that leading back from the parking spot where I park my '97 Mazda 626 there was a trail of dark drops. I had to leave quickly and so promply forgot about it. This evening I noticed it again but saw that there were two trails. I tried to find a wet spot and looked at the fluid, it looks dark and oily. I then checked my oil several times and found it full which would not make sense as there was alot of drops on the ground, looked like a large amount of fluid.
My biggest question is this: if it is a oil or some other leak, why does it only show up when the car is cold? ie, there are only trails of fluid that follow my backing up in the mornings, not my pulling in which would be when the car is at it's warmest (35min commute after leaving the car in the 70-80 degree sun all day).
Another question is this, the air temp just started to get warm so I have been using my AC again now, could that be leaking something?
I plan to call the dealer in the morning to see when I can take it in and get a rental but wanted to see your opinions before I did that. This is my wife and my only car so it's kinda important at the moment. Thanks for any help!
-spike
P.S. If I did not explain the probelm enough ask and I can try and elaborate.
-spike
