96 Pontiac Grand Am Sedan w/160K mi, 2.4L I4 Auto, FWD, ABS (Disc front, Drum rear)
For the last week or so, when I come to a full stop (like a parking space or red light), sometimes the 'Low Trac' warning lights up on the dash. Normally, this comes on when one of the wheels is spinning faster than the other.
I've checked the tire pressure and it's where it should be. The tires (Yokohama Avid H4S) have plenty of tread and show no signs of defect.
I'm not stopping in puddles, oil, loose dirt, etc. so I know I'm not sliding which can trigger the Low Trac or ABS. The ABS is not kicking in, which you can really tell on this car when it does.
This car is prone to wheel speed sensor problems (from various review sites), so that was my first guess. However, OBDII is not triggering wheel speed sensor (or any other) problems.
Any ideas/suggestions/tests?
