mcvickj
Originally posted by: gsellis
There is that video that Jeremy and company did of the Lotus vs the attack helicopter. 😀
http://video.google.com/videoplay?docid=-5404287952869985377
Originally posted by: b0mbrman
Originally posted by: randomlinh
I doubt the Ford GT TT will have anything on the lotus in terms of drivability. The only thing that can probably surpass it is the atom. I'd actually rather have that... complete and uter impracticality.... one hell of an autocrosser though.
Define "drivability"
Originally posted by: Cabages
He said he really liked the S2000, but that he wanted a convertible, and they didnt have any.
I saw a new MR2 the other day, does anyone know if it is expensive to import those over?
Originally posted by: BD2003
I have the same engine in my car. Are you SURE it spins to 10000? Redline on mine is 8000, but the limiter kicks in at 8350. The tach goes all the way up to 10k, but you certainly can't push it that far.
Either way, the little kick in the pants at 6000 rpm is fun. Does the lotus tranny make it easy to stay in lift when shifting from 1 -> 2? I must shift with absolute perfect timing to pull that off.
The tach goes to 10,000 and there isn't a redline indicated. I think the actual redline/fuel cutoff is 9200 or so. As I said, I had to hold it to around 8,000 in light of it not being broken in. I know the Lotus redline is higher than the Toyota redline because the engine management system is 100% Lotus.
Keeping the engine on the lift cam was never an issue. The 1 -> 2 shift didn't have any problemsat all. That could have been because I was hammering through the gears and didn't give the revs a chance to fall at all. Power shifting is fun! 😀
Things would get even more ridiculous with the supercharged Exige because the engine switches to the high-lift cam at a lowly 5250 RPM. Falling onto the low cam would take some serious driver error.
Originally posted by: Apex
Rev limiter is at 8500 on this car, however there is a bit of float, especially in lower gears. You can probably hit 8800 or so on the 1-2. You can hit whatever you want screwing up a downshift though. 😉
The sports pack is not worth it, IMHO. You're better off with Ohlins and aftermarket wheels.
There's no good shift kit yet (not counting the Ikeya Formula sequential), the B&M does nothing.
I found the gas pedal a little low for heel & toe, but my ankles don't swivel as well as some, plus I tend to use big toe/little toe.
You're definitely right about the interior size. 6'1" should be no problem except for those who think they way bigger than they are, or have HUGE torsos and tiny legs.
Originally posted by: RedArmy
What's the cars curb weight and hp rating? I bet the car I own is dead on with it, but weighs less.
im 6'3" and the only problem i had when i got in one, was geting in/out i had to contort myself really badly.
but the car is sex.
and btw, what the hell do you know about cars? you own a GM for christs sake... 😀
Originally posted by: HaxorNubcake
i know it's just a google search away, but how much is that car?
<- car noob
but the car is sex.
Makes sense. Even 4' tall people have to contort badly to get in & out. 😉
I only know what I read on ATOT, any similarity to real, first-hand knowledge is purely coincidental.
About 10 lbs per hp, give or take a bit depending on equipment.
<- car noob
$45k or so, normally equipped.
Curb Weight: 1984 lbs.
Horsepower: 190 hp
very few cars will match it.
its a track godess
Haxor: 45k or so.
Horsepower: 190 hp
its a track godess
Haxor: 45k or so.
Wow, my car with the air conditioning removed and getting lighter stuff puts it like right at 1900..and my engine puts out right around 190hp! I want to race this car on a track.
Horsepower: 190 hp
its a track godess
Haxor: 45k or so.
what car do you have?
Horsepower: 190 hp
its a track godess
Haxor: 45k or so.
1991 CRX HF with a B16 with ITR cams, headers, exhaust,AEM CAI, red line bumped to 9000, fidanza 7.5lb flywheel, Stg 2. clutch, Tein coils, KYB struts etc etc.
I actually just finished getting the car running. I <3 it
