YACT: Just changed out cap/rotor/plugs, oil on 3rd(or 2nd?) plug ONLY
Ns1
55,420
1,600
So I changed out the spark plugs on my car, and all of the plugs looked pretty normal except for one. On the 3rd(or 2nd iono) one it was covered in oil. Well, not covered, but there was a pretty substantial amount of oil on the white part.
I know somebody must have a good answer =)
How do I fix it? Is it a big big problem (big as in don't drive the car) or a simple fix?
The car itself drives fine, in fact the changing out all of the above fixed my biggest gripe ("iffy" to drive (hard to explain), low idle).
Thanks in advance =)
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
oil is most likely leaking past a worn valve seal or worn rings.
Ns1
55,420
1,600
uh is this something a fairly non car person can diagnose/fix?
SuperSix
True, a cylinder leakdown test will let you know if it's rings or not.. Does it puff a small amount os smoke on startup? A startup after the cars sits overnight?
SuperSix
Vavle seals aren't too tough, rings are a bitch.
Ns1
55,420
1,600
what color smoke are we talking about here? there's a little but not something i dont' see on otehr cars (liek my parents)
Quixfire
6,892
Bluish white smoke would be oil. Does your plugs sit in a well, like the center of a valve cover?
Eli
Super Moderator | Elite Member
8
It's probably a valve seal.. If it was worn rings, it seems like all cylinders would be equal.
speed01
1,167
Going by this, I would say that it is nothing more than a valve cover leaking onto the plug between the boot and the head...... Nothing really difficult to fix in most cases as long as everything removed is labeled so you know where it came from. Digital pics before removing anything can help alot with the reassembly....
Speed
T2T III
Speed
Speed, you said essentially what I was going to say. Chrysler vehicles (with 4 cylinder engines) were famous for having those smaller circular seals dry-up and crack which would then allow oil to pass through to the spark plugs.
What make/model of vehicle are we discussing in this thread? Is it a 4 cylinder engine or a 6 cylinder?
Mookow
10,162
Speed
Given his confusion on whether it was the 2nd or 3rd cylinder, I'd say its a 4 banger.
JC
5,855
73
When you say there's oil on 'the white part'....do you mean the part that is inside or outside the cylinder? If it's inside the cylinder, it's nothing a 'fairly non-car person' will want to get into. If it's on the outside, no biggie.
JC
