JulesMaximus
Well, I recently bought a 1996 Isuzu Rodeo with only 66,000 miles on it from a co-worker. I paid very little for it and it needed some work (which I did most of myself) but I had an oil leak fixed yesterday at a mechanic that I trust and the timing belt replaced. The mechanic told me that there was a fair amount of sludge built up in the engine (he says this is usually an indication that the oil was not changed regularly). I'm fairly pissed off at the woman I bought the vehicle from but there is nothing I can do about it now (she moved out of state).
Anyway, they are telling me that they can run a cleaning agent through the engine with a machine they have at the shop. Costs about $100, which isn't an issue, but it may also cause the lifters to make more noise after the procedure is completed.
As an alternative they suggest that I change the oil every 1000 miles for the next 5 or 6 oil changes to see if that helps clear up some of the gunk in there.
Does anyone have any experience with this? Any suggestions? Alternatives? Or should I just drive it into the ground and not worry about it since it is paid for? Obviously, I want to keep it in good running condition and I want it to be a good reliable vehicle that I won't have to sink a bunch of money into (more than I already have anyway).
