Originally posted by: DingDingDao
Originally posted by: RelaxTheMind
Yes get the belt changed as well as the water pump which is usually attached in fwd. easier to hit both at the same time. Dont know if they would be changing the pulleys too. There is definately gonna be some slack which throws your timing off degrading permance and gas mileage.
$1600 is a RIP.... I would do it for low low price of $1599.95!!!
j/k... but if that was a (im assuming "they") dealer price it would sound about right, even though they have the tools to make it oh so much easier. It could be pretty labor intensive as they would probably change the mechanical seal, and other gaskets and move/remove many other parts.
Yeah, definitely a rip. I drive an Audi A4, and my dealer quoted me $1600 for the job as well. If my German-made luxury Eurobox dealer can charge me $1600, how on earth does Toyota try to charge the same price with a straight face?
I found a local mechanic who used to work for Audi and is fully certified by Porsche and Audi. He did the entire job (timing belt, water pump, serpentine belt, etc etc) including parts and labor for $700. If you can't get a price better than that, keep looking. No way on earth is my car cheaper to maintain than yours.
