Originally posted by: Marlin1975
Depends on what parts are used, labor rate, etc... NOT cheap but it HAS to be done, and done RIGHT
Also when doing the belt on that car replace the water pump and seals. Also check out the belt tensioner.
Originally posted by: daveymark
95 Windstar - $90 at Firestone
LOL....Originally posted by: Marlin1975
No offense but Firestone is the last place you shoudl EVER take a vehicle.
1. If yoiu paid $90 for a timing belt on a 95 windstar you got taken. The only engines the windstar had that year were a 3.0L and a 3.8L, neither of which had a timing belt.
2. If talking about a serp. belt, I wish I could charge $90 to do a serp belt.
Originally posted by: glenn1
I just had my Acura done not long ago, your cost should probably be similar to mine. And as another person pointed out, it depends on what precisely you have done. I had my other belts and water pump changed at the same time, it ran me $590 at the dealer. I wouldn't doubt that the actual act of changing the belt itself isn't all that difficult, but with the Japanese cars like the Toyotas and Acuras they probably have to take out the radiator and half the rest of the engine to get to the timing belt. Either way, since basically all Japanese cars are interference engines, it's less expensive to have it changed than it would be to let it break while you're doing 70 on the freeway.
Don't claim you know more about the Camry than Toyota engineers. 😉Originally posted by: NutBucket
What gets me is (parents have the same car, '01 Camry) that the engine bay is HUGE! There's lots of room in there since it also fits a 6. The friggin' engine is crammed in there side to side. I think there's less room between the engine the shock tower then there is in my Accord. WTF sense does that make?! It wouldn't have cost Toyota anything to make a little more room between the two to fascilitate the replacement of the timing belt.
They are usually the esiest to change. Especially four cylinders. I suggest he take it somewhere but it is still an easy job.
They are usually the easiest to change. Especially four cylinders. I suggest he take it somewhere but it is still an easy job.
LOL, i'm sure that's the case. But i'm a stockbroker, not a mechanic. I tear apart Honda's balance sheet and SEC filings, not their engines. I want my car to work when the repair job is done, which is why I take it to the person who knows how to do that stuff and pay him to do it. Same deal when I was in the Army, just because I was blowing sh!t up for a living doesn't mean I could explain the chemisty of how C4 plastic explosive works. That's why Uncle Sam paid some poor slob minimum wage to make it in a factory rather than having us mix up batches of it in the barracks sinks 😉
Originally posted by: fredtam
Looked where you were to see if it was high. I'm in GA also and that is a little steep. Good thing dad is wealthy. I don't have that luxury.
Originally posted by: DrNoobie
I'm glad my car has a timing chain. No replacement 🙂
Wrong! 🙂 Timing chains stretch and break. They need to be replaced about half as often as timing belts if you want accurate timing. Most cars can go ~100k without noticable problems, though.
BTW, a timing belt probably costs less than $30 for that car. If someone quotes you $500 for parts, go somewhere else.
Originally posted by: amdskip
When should I do my 96 civic's? I have around 76,000 miles on it. I think if I do it I'll take it to a shop that is a fellow drag racer. All he works on is honda vehicles and hopefully he won't charge me too much. Timing Chain or Belt $185, that can't include labor, water pump needs replaced too right?
