Some of this has already been mentioned, But I have listed what may commonly be done in a "tune-up"
Oil: $3.99 (on sale, otherwise $4.99) per quart of Mobil 1 synthetic, 5w30 or 10w30 depending on if you are in a colder climate
Oil Filter:$2 to $7, I'd suggest either a PureOne PL14459 or a Wix/Napa 1334. Don't get a fram if you can help it. Some honda oem filters are Frams.
If it is automatic: then $4-$6 per quart for transmission fluid ATF Z1 from the dealer, you'll need 3 quarts for teh accord.
Spark Plugs are $2 each at Kragen/Schucks/Chekcers if get NGK copper ones. Platinum are more. I reccomend going only with NGK plugs in the honda engines.
Cap-$12-$18, Rotor-$5-$8, Wires-$35-$60
Fuel filter is about $15-$25 for the accord, kinda in an awkward place to replace, so not too easy to do here.
Air filter is $15-$25.
I think the 99 accords came with cabin air filters too, so thats another $20 or so.
Brake fluid flush, should be done every two years. Brake fluid is hygroscopic; it absorbs moisture over time, and water is not good for your braking. Get the rotors and pads/shoes checked out also. Adjust parking brake too.
With 130k miles, may want to think about getting new shocks put on (I like bilsteins), I bet the ones on there are worn. Also get the suspension bushings/components checked to make sure they aren't worn and/or rotted/torn. Not a bad idea to have the alignment checked and corrected if needed. Check the CV boots for tears and or wear.
Get the EGR system cleaned out. The EGR paths are known to clog with carbon on the accords. It requires removal of the fuel rail to access the EGR cover. I have a PDF with the procedure if you want to tackle this yourself.
Make sure your spare tire has air in it. And rotate/balance your tires. Check the function of all the exterior lights.
Thats about all I can think of right now off the top of my head.
