For some reason I thought it was 75,000 miles. my wife has the car now, but I'll check the owner's manual later.Originally posted by: thomsbrain
They may have changed it, but early 90's Hondas recommended the belt be changed at the 90,000 mile service. On my Accord, the timing belt is very expensive because you have to take a bunch of stuff apart to get to it. The Civic may not have that problem, though.
Originally posted by: Evadman
Just change it now. If a timing belt goes, your engine is toast. It is not worth it IMHO.
um, since when was new valves and new belt cheaper than just the belt?That is not always so, Hondas, Nissan, Hyundais are all know for bending a couple of valves (more if a V6,) but that does not mean that the engine is history. The valves can be replaced or a completely reworked head can be installed. Toyotas don't have an interference motor like the previously mentioned vehicles do.
OK, so the Honda is an "interference" engine?Originally posted by: Evadman
I wasn't sure.
I wasn't sure.
yepperz.
I wasn't sure.
yepperz.
Has Honda changed its design? My friend's 89 Honda Accord does *not* use an interference design. I know this because his timing belt broke and his engine simply stopped, nothing worse than that.
My 1995 Geo Prizm (Toyota Corolla) on the other hand, *does* use an interference design.
Originally posted by: Aquaman
My 90' Civic si says that the timing belt should be changed every 90000 miles.
Cheers,
Aquaman
Cheers,
Aquaman
Nice set of wheels there Aquaman![]()
