YACT: Help with 1990 Thunderbird..
IamDavid
My brother has a 1990 Ford Thunderbird and coolant is poring out of the exhaust.. I know its normal for some "water" to come out but this is way more then normal.. You can actually see the green coolant flow out.. It goes threw a gallon of water a day. lol Any guess on what it is? If I can find out I'm sure I can fix it..
Thanks.
head gaskets.
Only other thing it could be is a cracked cylinder head or engine block, but 95% likely that it's a head gasket. (Unless he keeps driving it like that, then he's going to warp a head)
If it's a 3.8 V6, I'd say it's a warped/cracked head. Less likely is a bad intake manifold gasket.
JC
