- Aug 17, 2000
- 21,204
- 66
- 91
I replaced the rear window defroster switch after the daughter seemed to have pushed it right through the dash, but it seems to be doing the same thing it was doing before she decided she didn't know her own strength.
The switch doesn't stay on. It acts as a momentary switch would. While you're pushing it, it stays on, but once you release it, it goes off, which it shouldn't.
There must be some sort of "timer/temp sensor" switch somewhere else in the circuit which keeps the circuit on until the defroster is up to temp.
Where is it?
What does it look like? What keeps a defroster circuit on?
Oger dodger wanna be's, point me right direction.
1996 Ford Escort
TIA
Where is it?
1996 Ford Escort
TIA
