- Mar 30, 2001
- 16,642
- 62
- 91
94 Ford Escort 1.9 ltr 126000 miles
For the past several days the car will idle up to redline when started, but only if the Idle Air Control (IAC) valve is plugged in. If i unplug it it idles fine but i get a nasty check engine light. I have replaced the IAC and the new one does the same thing as the old. Any sugestions? The transmission is about shot on this thing, and if i cant get it to idle right im not going to bother getting the transmission repaired and will attempt to trade it in and get a couple hundred for it....
Stoopid Phord....
Thanks
CrackRabbit
Stoopid Phord....
Thanks
CrackRabbit
