YACT: help me choose a new battery. ***final update in 1st post***
gotsmack
FINAL UPDATE
The pin that holds in the battery broke off so I had to go to a mechanic/ tireshop/oil change place that I trust.
They wouldn't drill out the bent pin for me but they rigged up a piece of wood that made the BOSCH battery they sold me fit in really nice. Warrenty kinda sucks 18 month full replacement and 60 month pro-rated.
the 700 CCA was impressive since the other battreies were only 590 CCA I think it's a truck battery
Price after tax came to $90.05
**New Q**
the autozone battery -duralast- is made by Johnson Controls so is the Diehard.
Now the question is: Do I pay the extra $30 for the diehard over the Autozone battery?
The diehard has 1 year full warrenty EXTRA and 4 months extra pro-rated warrenty over the Autozone one, so that might justify part of the extra $30.
Is it a different label only or are the Autozone batteries the ones that are at the ends of the tolerance curve when they are testing them? Does the longer full warrenty suggest that the Diehard has a higher MTBF?
****UPDATE****
You optima whores! I am not modding the battery well in my car! Getting the diehard because it seems most reliable of the list.
I need a new battery soon. I have the oem Volvo battery in there now but I know a dealership mechanic and he said that their batteries aren;t that great and to get an aftermarket one. So here are my choices.
NO OPTIMA because they don;t make one for my old but in great condition car, I looked. I am NOT going to MAKE and optima battery fit. I don;lt care how good it is, I'm not screwing around with the spacing of the battery well in my car.
Which one is the best? I live in Northern NJ so cold weather start is the most important part of chosing a battery for me.
NAPA brand, 75 months warranty. 595 Cold cranking amps $99.63
Autozone brand -Duralast, 2 full year warrenty +5 pro rated 7 years total 590 CCA $69.49
Strauss Auto- Ultra Silver, made by XI? 47 months warrenty? 600 CCA $54.99
Sears- Diehard International, 3 years full warrenty 100 month pro rated. 590 CCA $99
Are the other brands as good as Diehard? I've heard of Diehard but don't know if they are really good or just hype.
Thanks in advance
All of the batteries are the same.
They go down a line and they slap different labels on them.
3 will get Napa label, next 3 get Autozone, etc etc and they are the same battery.
I am not kidding.
I am not kidding.
You might be right about the Napa, Diehard, Interstate, etc. but I'm pretty sure the Optima batteries are a completely different type of battery altogether.
I am not kidding.
They are odd looking batteries.
I haven't checked to see if they are a different technology or just a different style case.
I am not kidding.
hell yes they're different
they're sealed also
Sears doesn't have the diehard gold for my car, I've checked both by calling in at the local store and online.
I also checked Optima and results were this
Please enter the following information about your car,
and find which OPTIMA is right for you.
There are no matches available for this vehicle.
VOLVO
All Models
1988 240, 740, 760
VOLVO
All Models
1988 240, 740, 760
A lot of times this is what you get, since Optima batteries are generally smaller than the batteries they replace. Just find the right post orientation and CCA to find the right battery, or check on a Volvo forum somewhere. I had this same thing happen on my Audi A4, and a lot of the guys on the Audi forums just fashioned a metal bracket to hold the battery in place.
Get an Interstate from one of their supply depots. My 1st Interstate lasted 9 years. Paid the same + $6 to jump to the next size up (1000 cca) when I replaced it (under $80).
Sears- Diehard International, 2 years full warrenty 100 month pro rated. 590 CCA $99
We used to run diehards in our dragster and then took a beating in pride.
Yup...I was going to suggest this one two.
Great batteries.
Don't buy one with more CCA than needed, and get the one with the longest free swap warranty, some are as high as 3 years.
I have had a Sears Diehard in my Ford Aerostar for 7-8 years and it is still working flawlessly. I will buy another Diehard if I ever get another battery...for any car.
How awesome of a battery do you REALLY think you need? I'm betting your car is around five years old with the original, two bit battery just about to give up the ghost. Is that not long enough service? You think a super, duper, awesome battery is going to last much longer? Think it will be worth the price premium for an extra year or two? Are you even keeping the car that long?
I don't want to spend more then $150 for the battery. I plan to keep the car for another 2 years and then give it to my sibling, so I guess the car has to last another 6 years? I take good care of it and it has <90K on it.
I think I'll just buy the diehard, unless someone knows better
You have GOT to be joking, right? The battery that lasted till today, can be replaced by another, with identical specs, for about $40.00. I'd certainly like to hear any rational explanation why this new one should cost any more than that!
What the hell do you mean they "don't make one for your car"?
I must be missing something.. that's like saying they don't make a battery for your flash light, lol.
