Hey all, my mom called me up yesterday and was like WTF (well maybe not those words). Her dashboard lights stop funcitioning. In addition there used to be a beeping sound when you left the head lights on and took the key out - that is now gone. I went home to investigate: I checked every fuse! (both in the car as well as engine bay). I found one fuse that had gone bad - luckily too - the fuse controlling tail lights was out. Unfortunately, replacing that did nothing...What can I do next.
Car Background:
1996 Mazda MPV 4WD.
Thanks in advance ATOT community!
Summary:
1) lights behind speedometer, tach, coolant, fuel gone! (makes night driving sketchy)
edit: 1.5) yes the dash dim switch is turned up all the way.
2) All fuses but one ok - visually inspected all - and tested suspected (as according to manual) ones with a multimeter
3) Replaced fuse for tail lights -they now work (no one knew that they didnt)
4) dont know what to do next?!
Car Background:
1996 Mazda MPV 4WD.
Summary:
