YACT: Help a guy out?
bapace
720
I am curious as to if there is a standalone 12 Volt DVD/MP3 player out there that shows On Screen Visualizations (Like Winamp and WMP) while MP3s are playing. Perhaps, shows the ID3 tag information also. I have a 2003 Accord V6 coupe and I was wanting to put a DVD/MP3 player in the console and have a LCD in the front pocket. Visuals during MP3 playback is a very big "want" of mine. Anyone able to help?
Thanks,
bapace
ajayjuneja
1,260
How about an in-car computer? You can build one of those for not so much and use the xenarc 7" vga touchscreen.
bapace
720
I have an LCD picked out that will fit perfectly in my dash, so the 7" is out. The LCD I am going to use is a 5.6" (6.25" with the casing). I don't think they make a Touch that small, which would lead to the need for a keyboard and mouse, which I don't want.
Thanks for the input though
-bapace
new2AMD
5,312
or just get a glidepoint touchpad to use as a mouse and the OSK in windows. There are some good front ends to use with a carputer. check out mp3car.com. its how I built mine.
