YACT: Has anyone ever changed drum style brakes?
tarheelmm
1,207
I have done the rotor style brakes before without a problem. I know the two are very different but I am trying to decide if it is worth doing myself? Has anyone every changed these before? Any ideas on the best way of doing it??
zixxer
7,326
do one side at a time so you can use the other for reference. There are these springs you depress and turn 180 degrees to remove.. go to a parts store and buy the $8 tool for depressing them
Vette73
21,503
9
A lot harder than disc. Best way to do it is jack up both sides and do one side at a time. If you forget where a spring goes just look at the other side.
Electric Amish
23,578
Yes I've done them.
They're a little daunting once you start, but after you get the hang of it it's not a big deal.
tarheelmm
1,207
Since I have never actaully looked inside of the drum, what parts do I need? I know about the spring tool but what else?
Fatdog
1,001
Just remember when you look at the other side for reference, it'll be reversed.
A pair of needle nose Vise-Grip pliers work very well for brake jobs. They can grip the springs and spring cup for removal without damaging anything.
Electric Amish
23,578
If everything is fine and normal, just the replacement brake shoes.
Safety glasses, needle nose pliers and vise grips are always useful as well.
Linflas
15,395
78
I used to do them all the time and never had any special tool for the springs. I just used a pair of pliers to grip and turn the spring caps. Don't forget you will need to adjust them once you have them installed and the wheel back on.
tcsenter
18,949
575
If the car has high miles, I would buy a brake parts kit for your vehicle. It has all new springs and stuff to replace the old ones. I typically use one can of brake cleaner per side, a couple clean shop rags, and some grease or brake assembly lube for the star wheel adjuster and contact points. You may need a little rust penetrating lubricant and a rubber mallet to get the drum off.
When you are refitting the drum over the new shoes, expand the brake adjustment thingy to make sure the fit is tight, then adjust the shoes inward just until the drum turns free (the shoes can even rub ever so slightly).
I couldn't find any really good illustrative sites, but I found this:
Servicing your rear drum brakes
Drum Brake Service
