i must say, I am not 100percent sure with the exact details, since it was a while ago. so here goes:
I changed the Spark plugs (Denso, regular, OEM's, gapped correctly), Spark plugs wires (autozone's Double Silicon), distri cap (autozone's Wells), and rotor (Wells) about 3 months ago. In the mean time of these 3 months, my car was fitted with new exhaust header (the old one was cracked), O2 sensor, and TPS. The gas mileage didn't improve after these subsequence fixes.
The gas mileage before all the changes was hovering around 31mpg, now it's about 27-28. The car is 1996 Toyota Celica 1.8L 7AFE.
so I wonder, is it because of the quality of the set I replaced with? (in other words: should I've gone with more expensive set of wires, rotors, and distri caps instead?)
Does the quality of wires, rotors, and distri caps affects gas mileage at all?
Okay, I may get flamed for this. but the motor has 210k miles on it.
However, how come the drop came so suddenly and not gradually, especially after those changes?
EDIT:
new candidate for the witch hunt: the K&N filter which is now 100k old. Could that be it?
I washed the filter 4 times.
EDIT:
