Originally posted by: LordMorpheus
Originally posted by: Maximus96
does having AC on high or low affect the gas mileage? I always thought it'll waste less gas if i have it on low instead of full blast on high. then i heard somewhere that if the AC compressor is on, it uses the same amount of gas regardless of the fan setting...which is true? this may affect my driving conditions this summer as two of my cars drinks premium...
When the A/C on the compressor runs, and I think it only has one setting. However, when you blow more air through the device (high setting), you add more heat to the expansion fluid (usually
RJ-12 in cars, these days) than you would with a low speed setting, so the compressor doesn't have to work as hard to return the fluid to a liquid on a low fan setting as it does on a high fan setting.
Could be the difference isn't huge but when you aren't cooling as much air you should put less drag on the motor.
