YACT: Engine Braking... is it bad for your car?
clicknext
Banned
Mar 27, 2002
3,884
I was just wondering if shifting to a lower gear (or is it called a higher gear? anyway lower number) to slow your car down while going down a hill is bad for it in any way? I live in vancouver and go up and down huge hills every day, so it would help to save my brakes a bit.
Sorry for my ignorance in this matter; I know neither the technicalities nor correct terms for cars. I'm not even completely sure that this is called engine braking...
sniperruff
11,644
AFAIK i don't think so. as a matter of fact i think that is what you're supposed to do: downshift on a hill. keeping a higher gear while you're going up a hill will lower the engine's rev and you lose power
well at least that is what an auto would do. and it makes sense...
and shifting often would only damage the tranny, not the engine itself...
but revving the engine up would probably use up more gas. but in this case it is unaviodable anyway...
HappyPuppy
16,997
It is wise to downshift when going downhill. As long as you pick the proper gear and don't overrev your engine it won't hurt a thing.
clicknext
Banned
Mar 27, 2002
3,884
Hmm, I meant to slow the car going down a hill, so I don't think we're talking about the same thing. Yeah, I drive an Auto and I notice it downshifting when I'm going up a hill.
I just wanted to know because I have to brake quite a bit to prevent myself from riding down the hill at 110km/h. My family has had to replace the brake pads once, after 1.5-2 years of usage, and now it's a-squeakin again.
JulesMaximus
74,600
1,004
No, it's not bad for your engine. It might put a little more wear on your transmission and clutch but unless you are driving down huge hills every day then it is much better to use engine braking than your brakes.
Edit-Just read that you are driving up and down huge hills every day. Are they long steep grades? If so, I would still use the engine to slow the car. The brakes on most cars aren't meant to be used constantly to slow a vehicle on long steep grades. They get really hot, warp rotors and fade quite a bit. The last thing you want at the bottom of a hill is severe brake fade. Hell, I've experienced severe brake fade after one or two stops from high speed in a sports car (older Mustang GT, not my current car). This is not something I'd want to experience at the bottom of a hill going 50+mph wondering what the hell I'm going to plow into to stop this beast.
clicknext
Banned
Mar 27, 2002
3,884
Does overrevving simply mean letting it go into the red zone?
Whisper
5,394
That would definitely qualify as over-revving, yes.
engine braking wont hurt your engine beyond revving in the red line.. as long as you are within rev limits for that gear.. you can use the brake to keep it in check.. but yeah.. it wont hurt a thing.. i do engine braking all the fscking time.
Originally posted by: sm8000
Does this apply to automatics any? I don't have a stickshift to drive ATM.
You cannot and should not engine brake in any way while driving an automatic. The best thing you can possibly do is just leave the transmission in D.
Steve
15,946
11
Good to know. Reminds me of the time some of us tried to jump-start a diesel minibus :D
slag
10,473
Thats nice.. You tell him its ok to do it unless he is driving up and down hills every day and then you re-read his post and see that he IS doing it every day and you still say its ok.
LOL.. your answer is right, but you don't know how you got there...
slag
10,473
Not true. Its recommended in every car I've driven (and I'd bet every car out there with an auto), that you can safely shift to D2 or D1 while going down steep grades to allow the engine to assist in braking.
Paragraph 4
Paragraphs 3 and 4
6th post
etc
Pacfanweb
13,158
59
Complete horseshlt. What the hell do you think they have other gear positions besides "D" for?
Of course it's okay to downshift your automatic. You think people that live in the mountains just ride the brakes all the time and never downshift?
Pacfanweb
13,158
59
Jump starting an automatic? Can't be done, guess you found that out.
mjrpes2
37
When I got my Class B one on the things required on the test is to remember to downshift while go up and down hills. And this is on Class B vehicles with an automatic transmission. You don't want brake fade.
