I just replaced the front pads on my 93 Land Cruiser. When I did, I noticed that the pins that go through the calipers and hold the pads in place were corroded, worn, and one was even bent slightly. I reinstalled them for the moment, but I'm thinking I should replace them. I had a problem last fall on my Tundra where the caliper jammed to one side on these pins and wore out a pad in about a week :disgust:
Also, should these pins be lubricated? So much dust & grit in there, I suspect lubrication may just be counter productive.
