1989 Chevy Corsica
4 cyl. 5spd.
187,606 miles
This problem has developed over about a week.
Before from a stop I'd shift into first gear and let out the clutch as I applied the gas. The car would move.
Now I do the same but the car remains stationary and I must apply more gas and rev the engine to make the car eventually move.
Before If i let out the clutch w/out giving gas it would die. Now I can completely let out the clutch while aplying no gas and the car will just sit there idling.
After the car begins movement and reaches approx 15mph, (this is about the shift point) I'll shift into second. Well, now there is hesitation between the point when i let out the clutch and when the car resumes acceleration. There is also vibration. For a moment it feels like its stuttering or something. This vibration is noticible between all of the gears besides 4th and 5th.
While cruising at highway speeds the car will sometimes begin to slow (moreso than usual) even when engine RPM is increased.
The cruise control now no longer works. If i set it at 50mph in 4th gear on a straight flat section of road, as the car begins to slow for no reason, engine rpm slightly increases and then all of a sudden the cruise will turn off, engine RPM drops and the car slows.
Does this sound like the clutch or transmission or something may be going out?
Whatever part/problem this may be.. how much am I looking at?
I live in oklahoma.
I suck with hand tools, so, I'd probably have to have someone else do it for me.
4 cyl. 5spd.
187,606 miles
I live in oklahoma.
