YACT: Check engine + rough idle after sitting for the better part of 2-3 months?
Viper GTS
38,107
433
Car in question is a 1995 Subaru Impreza, 1.8L H4.
I've been travelling for work & have spent the better part of the last 2.5 months on the road. My car has been sitting all that time, driven only once when I was home for a couple days.
Today I started it up, it's idling very rough + the check engine light is on. Also the idle speed jumps from 1K to 2K and back again with no throttle input.
Do I just need to let it run, or is this something I need to worry about?
Viper GTS
Heisenberg
10,621
I hope you changed the oil after letting it sit that long. Anyway, sounds like a problem with the idle air control (or whatever Subaru calls it). It may unstick itself after a while, or it may need to be looked at.
Edit: Could be due to the gas going bad, but IIRC it usually takes longer than 3 months for that to happen.
jlee
48,518
223
Old gas, maybe..?
I'd let it run a while - the Corolla I had ran a little rough for a minute or two, after not running for weeks.
NutBucket
27,127
616
Could it be something as simple as a stuck PCV? I say you give it a full tune up and report back.
BCYL
7,803
I would recommend changing the engine oil, then let it run for a while...
Was your gas tank empty or full when you left the car? It is always best to leave the gas tank full so there isnt room for condensation...
Viper GTS
38,107
433
Haven't checked anything yet, though there is no evidence of any leakage. I've let it sit for over a month before without incident.
The gas that's in it shouldn't be bad, though if it is I intentionally left it nearly empty so I could fill it with new gas. As for leaving the tank full, I had no idea how long I would be gone so I didn't want to put a full tank of gas in it... It is freezing ass cold outside, so condensation is a definite possibility.
Assuming there's no pool of oil or anything bad like that am I going to hurt it by just letting it run for a while?
I don't have time to take it anywhere or get it looked at, I'm flying out again Monday & will be gone for several more weeks.
Viper GTS
natto fire
7,117
10
This would be the first thing I would check (the IAC). It is usually bolted to, or near, the throttle body, and has a couple wires and sometimes coolant lines, going to it. It can be cleaned with carb cleaner. Gas usually takes longer than that to go bad enough to cause those problems.
Titan
1,819
another vote for change the oil. If it sat with a non-full gas tank your fuel could be messed up a bit as well.
Ronstang
12,493
18
That was my first guess and it is the #1 reason a fuel injected vehicle idles poorly. The gasoline is simply not old enough to make the car run poorly and even if it was it would not cause a wandering idle.
Viper GTS
38,107
433
Were it the IAC would driving it make it come unstuck?
I have to head out in a minute (different vehicle, thankfully) but I can take a look at it when I get back.
Viper GTS
Ramma2
2,710
Change:
Oil + Filter
Fuel filter
Air Filter
Gas
Check:
Plug wires
Plugs
Belts
Hoses
Vacuum lines
GuitarDaddy
11,465
Run by an Autozone or other parts store that will plug in the handheld computer under your dash for free and tell you what the trouble codes are
DivideBYZero
24,117
FYI:
Locate the two ECU check connectors, for most cars they are located under the steering column and consist of a black plastic male and female connector, and a green male female connector. The exact location of the connectors varies with the different year models, but generally they are located under the steering column on the drivers side.
natto fire
7,117
10
Viper GTS
Driving might help it, but chances are carbon has made the plunger stick. Carb cleaner gets it off really well.
DivideBYZero
24,117
If you suspect or get the MAF fail code, remove the connection to the MAF and spray Carb cleaner into it.
Soccerman06
5,830
How long is the idle rough? Does it go away after a few minutes? My old Bonneville had that kind of a problem and had a problem with the fuel injectures being dirty. But, if it is consistant, I would definitely change the gas and oil. The filters should be fine until their mileage expires.
Viper GTS
38,107
433
Originally posted by: DivideBYZero
Don't SPIDER this thread, dude!
No spiders, it's the gf's birthday so I have other obligations.
I only let it run for ~5 minutes, I'll try it again. It was rough the whole time, & jumping between 1 & 2K.
If it doesn't smooth out & is still throwing the CEL I can get it checked tomorrow. Beyond that I probably won't have time to get it dealt with since I fly out again Monday. I was just hoping to be able to drive it a little while I'm home.
[EDIT]OK better description of what's going on...
It idles at 2K, the CEL comes on, it drops to 1250, then it goes back to 2K & the CEL goes back off. It spends about 3-5 seconds at each RPM level, & cycles constantly between the two. It stops right at 2K and 1250, right on the nose like it's supposed to be there.
What's the verdict, let it run for longer or drive it to the auto store tomorrow & get the codes checked? It's pitch black and 15 degrees outside so I don't know how much I can do tonight.[/EDIT]
Viper GTS
Viper GTS
38,107
433
OK, just got out there & got the code.
It's flashing 24, which means that Jack Bauer is on his way to fix it right?
Actually thanks to DivideBYZero's link I know that means it is the IAC solenoid.
I guess now the service manual I spent 20+ hours downloading & piecing together is going to come in handy since I have no eartly clue where the IAC is located (or the throttle body for that matter...).
And I guess I need to go get myself a can of carb cleaner too.
Viper GTS
Viper GTS
38,107
433
Well I got carb cleaner but I couldn't get the bolts out (too old/rusty). I finally just said "screw it" and took it for a drive. The problem seems to have gone away, & it's back to its usual self.
Should I just take it somewhere (eventually) and get the sensor replaced? Or just not worry about it unless it proves troublesome?
Viper GTS
Heisenberg
10,621
If it idles and otherwise runs okay I wouldn't worry about it. If it starts to act up and the CEL comes on again then yeah, I'd have it fixed.
