Thanks to Roger & iamwiz82 from this thread, I pull the code from my 94 Jeep.
Guess what? it is 33, A/C Clutch Relay Circuit.
What is that? does that mean I can still drive my jeep even if the check engine light comes back on?
How do I go about fixing it? I like to do this myself, perhaps I knocked some wires loose when I was changing the oil?
[EDIT] After disconnecting the battery, I noticed I'm running low on coolant, refilling it, reconnecting the battery, setting off the car alarm, drive around with heat, no more check engine light for now.....
Thanks Roger, I'll need your help with the mysterious rattling sound later.
