YACT: Chassis lube question
RU482
12,689
When you take you car in to get an oil change, do they still grease the chassis? And, what the hell does that mean? I've got an 01 civic and I just changed my own oil, is there something more I should be doing besides draining the engine oil and changing the oil filter?
Thanks
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
Generaly it is included, but only if you ask. It takes a while to lube it correctly, and hit everything.
for the most part, every moving part on the chasis/suspension is greaseable. Look for little "nipple" looking protrusions. They hook a grease gun up to this and force out the old greese while putting in the new stuff. If the old stuff is left in, it can pull in contaminants from the road and start eating things. Lube = good.
schizoid
Banned
May 27, 2000
2,207
Heh.
Chasis.
"lube".
As in, "boy, I'd like to 'lube' her 'chasis'".
(of course, in this case, when i say "lube her chasis" I'm not refering to automotive maintenence but rather am making a clever sexual innuedo)
Zim Hosein
Super Moderator | Elite Member
65,291
403
Originally posted by: schizoid
Heh.
Chasis.
"lube".
Evadman
Feb 18, 2001
30,990
Heh.
Chasis.
"lube".
I like how he explains it for the slow members :p
schizoid
Banned
May 27, 2000
2,207
Heh.
Chasis.
"lube".
Well, you know...how many of these kids know anything about females, eh? I'd probably still have to explain it to them if I said "I'd like to engage in coitus with her" or something like that.
RU482
12,689
oh man, I should've know someone would pull the old "lube her chassis" out .
Ronstang
12,493
18
Most cars no longer have any grease points on the chassis and it has been this way for years.......
schizoid
Banned
May 27, 2000
2,207
Oh I'll pull something out...if you know what I mean.
RU482
12,689
That's what I was wondering about
schizoid
Banned
May 27, 2000
2,207
da wangggggg??
Nah. If I pulled that out, Weezergirl might fly off the end of it. She's been stuck down there for awhile now.
SlowSS
1,573
Originally posted by: yellowfiero
most newer cars have greaseless fittings, so there's not much you can do.
True...Unless, you installed after market suspension equipment like I did,
my LCA and APHR does have grease fittings.;)
Ornery
17
That's exactly why I'd like to know why so many people here think the dealer's parts are superior to after market. I'd much rather have a grease fitting in a joint, than have it supposedly "permanently lubed".
LAUST
8,957
I'm with you, aftermarket can be far superior (U-joints, Fuel Pumps, Lockers, Motor/Tranny Mounts) those are just a few things that came right up as I read your post that I have installed on my current and past vehicles because of their superiority to ANY manufacturer.
