Originally posted by: forcesho
i use iridium.. loved it... you can find it on ebay for cheap.. depending on what type of plug thats in there... plantium supposely can go up to 100,000k
Originally posted by: DurocShark
Make/model/year?
Originally posted by: 0roo0roo
ebrake engages rear brakes with wire tension...its not locking the wheel.
Should still lock up the rear wheels if you pull it up as hard as you can. If the handle is reaching it's stop before you can't pull it any further because of the tension on the ebrake cable, then the cable has stretched and you need to adjust it.
They have performance plugs that are supposed to make a difference...most of it is marketing ploys... The key to a good plug is to make sure there aren't carbon deposits on them, and to make sure the spacing is correct so you get the optimal spark based on your car's specifications.Originally posted by: NutBucket
OEM plugs work best 90% of the time.
Did using Iridium plugs make a difference on your car?
It did on mine.. I was getting piss ass poor mileage off my car.. 13 gal gets me around 280.. after i switch, i got about 330-350 even on heavy acceleration..
First 30k - oem honda
2nd 30k - oem honda
3rd 30k - ngk iridium - mileage got better after 60k switch..
