YACT: changed my oil for the first time today
thomsbrain
18,148
I've done a few small maintenance jobs before (new alternator, small electrical stuff), but until today I've never changed my own oil, mostly for fear not doing it right and having the oil all leak out.
Anyway, $100 in tools and supplies, 2.5 hours, 2 trips to the auto store, 1 trip to the hardware store, 10 billion cuss words, 1 big oil spill, two filthy hands and arms, and 5 empty oil bottles later... i changed my own oil! :roll: :D
whew. i'm not sure its worth it. of course, next time, i'll only need to spend $10-$15, and i'll know the oil shoots FAR and FAST. but it will take like 15 changes before i make my money back. there is something to be said for spending 10 minutes having someone else do it and not getting filthy or having to worry about recycling.
rbV5
12,632
LOL, thats kinda why I do it myslf.
radioouman
8,632
I do it because it forces me to get under my car and look for other signs, such as leaking coolant, transmission fluid, or worn belts.
I stock up on oil and filters when they go on sale, and I never empty my oil container until it is full. I have three vehicles, so I save quite a bit over the quick change places which I don't trust anyway.
Fern
26,907
174
Takes me less time to change it than drive 5 miles to the nearest oil change place. But I've been doing for it years. Not sure why it would require $100 in tools either?
Fern
iamwiz82
30,772
13
$100 in tools?
A socket and socket wrench costs $10 at the local auto store.
vi edit
62,484
8,345
Originally posted by: iamwiz82
$100 in tools?
That's what I was thinking.
Maybe $10 for the set, $25 for a set of ramps & stop blocks, and then another $5 or so for an oil filter wrench.
But $100? Yikes.
Queasy
Moderator<br>Console Gaming
Aug 24, 2001
31,796
$100 in tools?
But $100? Yikes.
I didn't know Monster Cable was starting to make tools! :laugh:
rbV5
12,632
$100 in tools?
But $100? Yikes.
They have for quite awhile under the "Snap On" brand.
UCDAggies
148
Do people still change oil from under the car. Every oil place I have been though has removed the oil from under the hood.
vi edit
62,484
8,345
I have to say though, a lot of times it's easier just to kick it off at the stealership and have them do it for $25. No messing with left over oil or worrying about spills or drips on my garage floor.
Plus I get a free car wash and interior cleaning with the visit..so that's a nice bonus.
Looney
21,938
I did it once and only time as well. It was right after watching The Notebook by myself and crying.
thomsbrain
18,148
i needed a jack, stands, socket wrench set (didn't know what size the plug was, and none of my wrenches were big enough, so i couldn't easily find out), filter wrench, drip pan, gasket, filter. my car is too low to not lift it up, and you can't reach the plug or filter without lifting the car. by the time i bought all that crap and paid tax on it, it was nearly $100.
in retrospect, i should have bought ramps instead of the jack and stands. they were a pain in the ass and cost more.
radioouman
8,632
The drain plug is always on the bottom of the engine. They probably remove the oil from underneath, in the trench.
biggestmuff
8,201
bwahaha. Stop going to Jiffy Lube and the Wal-Mart auto center.
vi edit
62,484
8,345
Eh? Oil pans/plugs are on the bottom of the engine block. You really can't reach it from the hood. You still have to get under there one way or another.
UCDAggies
148
Why did you use a drip pan. Isn't that old fashion. I don't know of any place here that uses a drip pan to change oil. No one goes under your car around here when they change your oil.
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Changing your own oil used to be on the list of things you were supposed to know before you left home along with how to read a map, laundry, iron, tie a tie etc.
UCDAggies
148
Not really. I have seen them do it. They use a machine that sucks the oil out of the car.
thomsbrain
18,148
from what i understand, they do make pumps to try to siphon it up, but you're not getting all of it, and you're not changing the filter, so what good does that really do?
Jahee
2,072
Exactly, far easier to just undo the plug and let it drain!
UCDAggies
148
You don't have to go under the car to change the filter.
QueBert
22,975
1,175
I'm not a car expert by any means, but I have changed the oil on my car, there is no way in hell you could possibly change the oil filter on my ford Taurus without going under it, I have yet to see a car where the oil filter was anywhere but underneath. Care to fill me in on how exactly I can change mine without going under?
