YACT: Car Makes weird noise near wheels when making sharp turns.
dxkj
11,772
1991 Chevrolet Cavalier, manual
Everytime I turn the wheel far there is a high pitched noise emminating from near the tires. Steering is also a bit harder than normal (I thought maybe the front tires were really low)
Any ideas?
dxkj
11,772
Originally posted by: nourdmrolNMT1
ball joints??
MIKE
Possibly.... I know its not belt action (which is normally assotiation with power steering making noises)
NutBucket
27,162
638
Hmmm. Hard to steer? Doesn't sound like CV joint to me. I'm not sure I know what to suggest. CV joints click when they're worn out. High pitched sounds are either brakes or wheel bearings. If it were wheel bearings the sound would probably be present all the time. Again, I don't think either of those would make the steering effort increase.
teckmaster
1,256
How many miles are on the car?
I'm guessing cv joints, tierod ends, or axles(depending on mileage)
Quixfire
6,892
Check for loose splash shields in your front wheel wells. Other than that it could be a dried out tie rod end or ball joint.
dxkj
11,772
75k miles...
dxkj
11,772
thanks for the suggestions. I'm going to take a closer look later. I was driving to work when I noticed this.
C'DaleRider
Guest
Jan 13, 2000
3,048
Originally posted by: Asharus
Check the power steering fluid.
Like he said......start with the simplest things first and check your power steering fluid. If it checks out OK, then progress through the suspension components until you find it. And you did check your air pressure in your tires, right?
beatle
5,661
Is it kind of a groaning sound? My parents had an 87 Aerostar that ate power steering pumps for breakfast, lunch and dinner. They always made a groaning sound when turning, especially at lower speeds where the steering needs more assist.
