DingDingDao
So my brakes are about to buy the farm, so for the fourth time in the life of my car I'm going to replace the rotors and the pads. Since I need to do this anyways, I'm looking to do a upgrade that won't break the bank. I have an Audi A4, by the way.
Option 1: A8 rotor upgrade. This increases the rotor size from 288mm to 312mm, while still using the stock caliper.
Option 2: An aftermarket company is offering a similar upgrade, using a floating 332mm rotor that uses the stock caliper as well. Quality isn't an issue here -- the rotors are manufactured by Zimmerman, a German OEM supplier.
The pros and cons of each option:
Option 1 Pros: Parts are readily available from Audi and OEM suppliers.
Option 1 Cons: The A8 rotor is 20mm smaller in diameter than Option 2.
Option 2 Pros: Larger rotor size increases swept area, reducing fade the most and increasing stopping strength. Also, replacement rotor rings are cheaper than a whole A8 disc.
Option 2 Cons: If the aftermarket company goes under, I'm SOL when I need to replace the rotor rings again.
Prices for both kits are within $50 of each other, so the price isn't that big an issue.
What do you guys think? Also, solid/slotted/cross-drilled or a combo?
