Under moderate braking from say 60-45 in my mother's 97 accord EX sedan (car has abs), the steering wheel shimmies/shakes or vibrates a little (from side to side), I'm not sure if there is pulsation in the brake pedal. The steering wheel does not shake/vibrate at any other time; only when braking from ~60+ with moderate pedal effort.
Brembo blank rotors with akebono ProACT pads in the front. These are less than 10k miles old.
Driver's front (front left) rotor surface appears to have some glazing (but no glazing spots or dots) on the outside face, but none on the inside face.
The ProACT pads worked great at first but now this? I know Akebono puts out quality stuff.
I'm going to try and re-bed the pads in tonight when there is less cars on the road and see if it ain't uneven pad deposits or glazing of the pads or rotors. If I cannot fix this myself I'll have my mom take it to our indie honda mech. Maybe the ProACT pads aren't all that great, though I do know the OEM pads are ceramic based like the ProACT.
I doubt its warped rotors because my mom doesn't drive that aggressively. I don't think its sticking caliper pistons. I have flushed the brakes myself (Valvoline synpower) using gravity method and the pedal feel is good.
It did this shaking both before and after I rotated the tires today. I used a torque wrench to tighten the lug nuts to 80 ft.lbs.
I just though of this, could it be the tie-rod ends? But wouldn't it [steerwheel] vibrate all the time then?
Any ideas?
Thanks in advance.
Any ideas?
Thanks in advance.
