YACT: Battery light comes on randomly.
djheater
14,637
2000 Dodge Neon manual
I'm not certain what the battery light is monitoring.
It comes on occasionally, maybe once or twice a week, for the last 3 weeks. The first time it happend I took it in to the shop and they did an electrical system test and replaced the battery.
It's in the middle of driving, and is not accompanied by any perceptible loss of power. I don't have any problem starting the car, and none of the peripherals have any issues.
Doesn't happen every time, just occasionally.
I ask about spark plugs, because I have noticed, on occasion, a gap in acceleration in the upper forties....
Any ideas?
nakedfrog
58,175
12,350
The gap in acceleration means you probably need new plugs and/or wires. But I can't see how they'd be causing your battery light. You should probably have the alternator checked out, or maybe look to see if the belt seems like it's slipping.
The battery light should be monitoring the voltage level.
funboy6942
15,295
391
Alt/Regulator is getting weak causing the light to come on. Gonna need a new alt/regulator, not sure on that year if the voltage regulator is part of the alt or not. If not good for you, cheap easy fix. If not sucks to be you, gonna cost a few bucks can be a pain in the ass depending on where its located.
BoomerD
62,933
11,324
Battery light monitors your charging system. Has nothing to do with the sparkplugs. Weak battery, failing alternator, slippijg belt could all cause that. Get it checked.
funboy6942
15,295
391
Cant be a belt, its got a one belt to run them all, one belt to bind them, and if it fails in the middle of bfe bend over cuz your fvcked. Said he just changed his battery, cant be plugs, thats just absurd thinking there, so one and only one thing left.
BoomerD
62,933
11,324
Belt doesn't have to break to just slip enough to let the alternator not put out a full charge...however, with a serpentine belt, AND with a new battery, I'd suspect a failing alternator. (IIRC, the VR is inside the alternator, and not EASILY replaceable without replacing the entire alternator.)
djheater
14,637
Sort of what I figured. I'm coming to the conclusion that I disturb EM fields. Every car I've ever had the alternator goes out on eventually, and certain street lamps dim whenever I go under them. It's unnerving.... just call me powder.
All of which means the shop couldn't find the problem so stuck me with a new battery 'cause it was a quick $50
j00fek
8,099
QFT get the alternator checked and the battery. (lol sparkplugs :Q)
BoomerD
62,933
11,324
Originally posted by: Tom
could be your shorts.
ROFL! OR, it COULD be a bad ground somewhere...
DEfinitely something to have checked however.
OutHouse
36,413
616
eh, not really. a bad alt not charging the battery is a fast way to fry a battery. depding on how long it was going on its a good idea to replace the battery if you have a bad alt. so if i were you i would get that alt replaces as soon as possible to get the load off running your car.
teddyv
974
Bullseye - probably the brushes. Not sure if the part is available separately or part of the Alternator - the alternator (part# F4000-165567 maybe?) runs about $200. Can you change a tire? If so, think about replacing it yourself.
Crucial
5,026
DING! DING! DING! Why fix the actual problem when you can be back on the road with your money in their pocket. They're all just parts changers. Rarely do you get anyone who actually diagnoses the problem and fix whats causing it. Something had to kill the battery assuming it wasn't 7 years old. I'm doubting they did an electrical system "test" as it would have shown a weak charging system.
Zenmervolt
Elite member
Oct 22, 2000
24,512
21
Most likely is a slipping alternator belt. Check that and replace it. It's the simplest and cheapest thing. It's possible that the alternator is starting to fail, but check the belt first.
EDIT: The Neon does NOT use a serpentine. It has a belt for the alternator and a separate belt that runs both the A/C and PS. These acessory belts are indeed multirib and not V-belt, but they are not true serpentines.
ZV
funboy6942
15,295
391
ZV
I stand corrected it doesnt use the one belt for everything for that year.
OP check the belt. Should have but a 1/2-1 inch of play no more. Since its a multi-rib belt small cracks in it is normal but if it hasnt been changed in a long time should prolly change it, Get the alt checked for free at any pep boys/auto zone, and if you change the alt, change the belt at the same time for its only a few bucks more for peace of mind down the road.
alkemyst
83,967
19
ZV
1/2-1" is a bit much :) I have 3 separate belts in my Nissan..7-8mm with a 22lb force is the limit, that's a little less than a 1/3". On my 66 mustang about the same I think, definitely not an inch. My 88 GT had a serpentine and the tensioner pulley died...even then just a lot of noise and the belt didn't flex 1/2"
Squisher
21,207
66
Like others have said, belts, maybe alternator (they can test it), but it could be your voltage regulator and mine ('91 Dakota) was in the engine computer ($125 rebuilt, arg!!)
