YACT - Battery Height Accessory
TechBoyJK
16,699
60
alright, i need a new battery for my 2000 honda accord with about 1000rms of car audio power. I need a good one, and while optima and kinetic batteries are made for car audio, my research tells me the top of the line batteries at walmart should be more than enough for my car as is. So I go up to walmart and I find one of their everready maxx batteries. Looked in the guide book and found that they had a battery that would fit in my car, but it may require a height adapter.
well i went to install the battery, and if i try and put the battery in, its too wide. If the battery mount was about 6 inches higher, it would clear the stuff that is blocking it and could be installed..
i cant this device any where online... ive looked on autozone.com, google, etc... anybody know about this?
Pikachu
1,178
I'm certain many of the people you annoy with that crap, will be more than happy to shove it in for free!
TechBoyJK
16,699
60
lol, my car is dynamatted so even when its loud, you can barely hear it outside of the car.
doze
2,786
You already shelled out the cash on your system, bring that POS back to walmart and get the right battery.
TechBoyJK
16,699
60
honda's require special size batteries... the "right" battery will need the same thing. its a matter of size. until i can shell out $400 for a kinetic battery, this $70 high capacity battery from walmart will be fine, considering its made by the same company that makes optima color top bats
