Girl at my work has a 2001 Corolla 5-speed, 40k miles... she is from Venezuela and knows nothing about cars and doesn't have access to work on it. Yesterday she said her check engine light came on so I told her to go to Autozone to pull the codes. Today she came into work with 3 codes with diagnosis and here they are:
Code: P0440
"The PCM has determined that a malfunction exists in the evaporative emission control system."
Code: P0441
"The PCM has determined that the purge flow in the evaporative emission control system is incorrect for the current engine operating conditions."
Code: P0446
"The PCM has determined that a malfunction exists in the electrical circuit for the vent control in the evaporative emission control system."
So all 3 have to do with the evap. emission control system. Her toyota dealership said it sounds like a vacuum leak? Roger or anyone else have any idears? Thanks guys.
Code: P0440
Code: P0441
Code: P0446
